Hey guys, been having some trouble with a pull to right while driving. If the steering wheel is centered the car pulls pretty good to the right all the time. If I have the steering wheel cocked about 5-10 degrees to the left it goes straight for a little bit but still eventually goes right. I recently got new tires and struts and figured it would correct itself after they were installed and an alignment done, but it did not.
I've made sure the tires are evenly inflated, I rotated the front tires to see if that was the issue, and I checked the brakes to make sure the brakes aren't the cause. I also had the shop re-do the alignment making sure the steering wheel was centered. I will post a picture of my alignment specs.
Do you guy's have any other thoughts? Car has low miles and is in great shape. I know the alignment specs are "within spec", but would the difference in camber cause the pull? Or the very tiny amount of rear thrust angle?
