I need verify the axle ratio for my 2005 Nismo 4x4 with automatic transmission. I believe it is the 5A M226 with 3.357 gear ratio. I'm asking because my front differential is failing and I need to replace it soon.
Thanks Rayzzz. My Nismo likes my money
Cut and pasted from this old thread:
http://www.clubfrontier.org/forums/f62/what-axle-gears-do-i-have-my-2nd-gen-32992/
Model Axle Gears
XE KC 4x2 5M C200k 4.083
XE KC 4x2 5A C200k 3.692
SV/SE KC 4x2 6M M226 3.538
SV/SE KC 4x2 5A C200k 3.133
SV/SE KC 4x4 6M M226 3.538
SV/SE KC 4x4 5A C200k 3.133
SV/SE CC 4x2 6M M226 3.538
SV/SE CC 4x2 5A C200k 3.133
SV/SE CC 4x4 6M M226 3.692
SV/SE CC 4x4 5A C200k 3.357
NISMO KC 4x2 5A M226 3.133
PRO-4X/NISMO KC 4x4 6M M226 3.692
PRO-4X/NISMO KC 4x4 5A M226 3.357
NISMO CC 4x2 5A M226 3.131
PRO-4X/NISMO CC 4x4 5A M226 3.357
SL/LE KC 4x2 5A C200k 2.937
SL/LE KC 4x4 5A C200k 3.133
SL/LE CC 4x2 5A C200k 3.133
SL/LE CC 4x4 5A C200k 3.357
yes
Model Axle Gears
PRO-4X/NISMO KC 4gear ratiox4 6M M226 3.692
NISMO CC 4x2 5A M226 3.131see the info you posted but
Thanks I see the info you posted and would I be correct saying mine is the one on line
PRO-4X/NISMO KC 4X4 5A M226 3.357. Making my front differential Ratio 3.357 ? Also can I identify the differential by a part number on the diff. Finding number could be fun.
Thanks Rayzzz My Nismo likes my money
