nevermind...i'm an idiot
O owen_kingpro4x · Registered Joined Mar 11, 2017 · 136 Posts Discussion Starter • #1 • Dec 3, 2017 (Edited) nevermind...i'm an idiot
Zedbra · Rogue Admin 2007 LE 4x4 Crew Cab Long Box Joined Mar 31, 2007 · 13,597 Posts #2 • Dec 4, 2017 I can see your original post and it is details like that circumstance and sharing what you learn that helps others on this site. You should consider noyt removing it and telling us how you solved the issue in the future.
O owen_kingpro4x · Registered Joined Mar 11, 2017 · 136 Posts Discussion Starter • #3 • Dec 6, 2017 I only removed the post because there was no issue to solve...i was simply looking at the wrong connector when hooking up the bluetooth module for those needing a link, this will tell you what to do: http://www.clubfrontier.org/forums/...it-aswc-bluetooth-bypass-info-pointers-79162/
