1 - 17 of 17 Posts
Hey guys, did my Titan swap today! Everything went fine but the Titan brakelines I got will not work(not long enough). I don't need ss ones, but I tried calling prg but they don't answer cause they r closed for some reason. Called AC and they could do it but it would take 4weeks!
What do I do?! I need my car back as soon as possible!!
If you are really in a pinch, use a piece of rope from the caliper to the truck. Then cycle the suspension to find the correct legth of rope. You will want it to be a little loose but not enough that it would get caught it the suspension and rip off.
Well here's where I stand:
truck is on the lift at school with stock lines under a lot of stress
found a guy in town who can make me stainless steel lines for 100bucks... Same price prg lines overnighted would still be cheaper.
So I got that situation under control but how long do I need them? I told him 14inchs
IIRC, you have to pull a small clip out, and you might even have to disconnect the line and reconnect it. I havent looked at it in a while. If you do disconnect it, just be sure to bleed them. Have a friend pump the brakes, then hold the pedal down. Then open the bleeder on the caliper for a sec or two adn close it back. Then repeat about 5 times. Do both sides this way.
I don't remember a clip for the front brake lines.. Just a grommet/clip for the ABS wires..
Been a while for me too!
1 - 17 of 17 Posts
