1 - 12 of 12 Posts
fire it up, pop the hood, and start listening for the noise of air sucking
i would assume vac leak is under the hood, but gas cap most likely? theres not enought vacuum in the tank cuz of the cap and it throws a code? give it a shot
how is the truck running, are the rpms dipping alot when sitting at idle?
get the code and run a search, the 05s don't have a filter on the vacuum canister purge valve. The valve gets dirt in it during a purge cycle. Bingo your hosed. It is a free fix until the warranty runs out on it. Then it is bank.
With 100k you are out of warranty, but see if your dealer will good faith you. It is a known problem, and there is a tsb on it
1 - 12 of 12 Posts
