So as i was lifting my truck and got to the driver side upper ball joint I was hammering the spindle to break apart the control arm I hit my ball joint thread and it ended up cross threading :serious: I'm thinking of either tap and dying the thread to save the ball joint or purchasing a new one
What do you think?
If I do purchase a new ball join anyone have an idea of how to replace it manually without having to use a press?
Take your arm to a parts house that does machine work. They will likely be able to install it, for a nominal fee of course.
Good luck.
If there's room to get at it, I'd try a thread die on it to clean up the threads. And likely get a new nut too.
If you can't save the thread, it will be much easier to replace the whole control arm. The whole assembly is not much more than a new balljoint. Depending on the mileage it may not be a bad idea to replace both of them anyway. A quick search on RockAuto show you can get a new joint for about $20 but then you would still need to install it or a whole new uca with new bushing and balljoint installed ready to go for about $45. If you want to install a new joint, just rent a ball joint press from Autozone or Orielys. Its usually a $50-100 deposit, but you get it back when you return the tool. Although its kind of a pain in ***, changing the whole arm would be much easier. You could also ask around on here and buy a used set of arms, they typically go for very cheap ($25 or so). To avoid this headache next time pick up one of these from Harbor Freight for less than $20: Tie Rod and Pitman Arm Puller
It makes quick work of undoing the upper ball joint form the spindle without beating the crap out of it. Good luck!
If there are enough miles on it, the ball joint will likely spin in the socket if you try retreading
it. If you have to buy a joint and have it installed, but an arm.
Good luck.
