1 - 20 of 43 Posts
Hey I going to hook up my new CB Radio tomorrow but not sure of how to run the antenna cable. I am going mount it in the bed and was wondering how everyone ran there antenna cable to the bed. I know some of you guys have your antenna in the bed. So let me know what you have come up with.
So far all I see is the hard route of going from the radio box through the firewall and under the truck to the bed. Anyone have a simpler way of doing things???
what if you took it under the truck and drilled a small hole near the floor. Might be difficult locating where to put it, but when I do get mine that is how it is going to go
Discussion Starter #4 (Edited)
isn't there a grommet under the passenger or driver seat?
I have no clue. I will take a look tomorrow. If so that would kick a$s. I am mounting the radio in the center console so that would work perfect.
Drilling through the floor is my last choice. I am willing to drill it if I have no other options.
^there's grommets/plugs everywhere in the cab.. pop one or a few out and thread a wire though to see where it pops out; pulling a portion of the carpet/padding will be required. :willy_nilly:
I used a "raw" pl259 connector for my antenna so a small(er) hole is used.
G/L!
I put me antena on the front, so I can't help you with a bed mount. But I can say that the way I did mine was through the main cable hole in the firewall in front of the driver seat.
But mostly I wanted to tell you to check out my thread (link below) that shows how I mounted the radio itself. You have to scroll down a bit because it was kinda 2 threads in one. Check out posts 10-12
http://www.clubfrontier.org/forums/f23/my-new-install-next-mod-46899/
im doin mine tonight or tomorrow...in the bed, on the front corners there is a pocket on both side in the front corners if you feel up in there you will see. the pockets run straight down thru so you can run the wire for the antenna up thru there. you will just need to fish a wire or string down thru to pull the wire up thru there. if i can find my cam i will post pics to show.
Discussion Starter #10 (Edited)
thanks everyone
I will check it out when I get off work.
that looks nice, I have the same radio. I am installing mine in the center console and I think I may hook up an external speaker like you did. What speaker are you running and where did you get it?
Behind the rear seat on the driver's side.
Discussion Starter #12
just looked behind my seat and see that vent. Thanks a lot mike. That just saved me a lot of time.
Banned
Im get mine hooked up properly in time for Harlan. Thanks mike
Discussion Starter #14
Banned
wow, use English much?
I do but at that very moment i was doing some research for my solid axle swap. I was looking up brackets and upgrades to do to the D44.
Discussion Starter #16
You should look up Webster and begin reading that haha j/k
I can't wait to get my CB hooked up. I need to go buy a few things for the mic cable and antenna cable.
Banned
What antenna cable do you plan on going with ??? with that said you should ask Mr.Plow about his mod he did to put it on his Utli-trac system. If you have it that is.
remember that vent has a "one way" flap dealie... some dust/crud will come into the cab with it not sealing completely.
Discussion Starter #19
I am going to make up my own mount for the utilitrack system. The antenna is on a magnetic base for now though.
hmmm I might have figure something out with it then. Thanks for the heads up.
Banned
Yeah my antenna is on a magnetic base too lol
1 - 20 of 43 Posts
