1 - 7 of 7 Posts
So about two days ago i had a metal squeaking coming from my rear drive line. So instinctively i was like **** just blew another u-joint. However i looked at the u joint and it seems to be in good condition(and its only 15K old tops). But the squeaking is definitely coming from that region. I WD the hell out of it and it seemed to make it worse. Any ideas?
* I do have the whole 4-4.5 inches lift in the front but i dont see that being a problem.
Mostly under engine load but occasionally while coasting. Also noticed a metallic popping while going from drive to reverse and vice versa occasionally
Might be time to pull the pumpkin cover!
1 - 7 of 7 Posts
