Well I read the write ups on the automatic fluid changes and the front and rear diffs are simple but im confused. Sorry shinnermiller but this quote made me confused.
" Edit for this post too: Forgot to mention about the T-Case fluid.. This stuff was YUCK as I drained it. It wasnt quite as burned and nasty as my transmission fluid, but you could tell it was a little overdue! No debris in this one like the front diff. Fluid was clean as it drained, but used. I think I'll do the T-case every 30k when I do the transmission service. "
So is the transmission is same as the Transfercase?? Sounds like you changed 4 sections totall. I know im a noob but had to make it clear. Also what kind of fluids will i use for a manual transmission?? Any help guys would be awsome. We don't have pep boys and stuff here, so i don't know where to get the fluids, we have only like checkers, automotive and stuff. but i'll call around, i was thinking my local nissan would sell those geniune fluids
