1 - 3 of 3 Posts
Frontier
Crew Cab
2wd
6 cyl
2006 model
Hey I'm looking for a Roof Rack that will fit securely from the upper door frame. Any web-links you guys know of I can go check it out to see if it'll work?!!????
So I'm needing help finding the right Roof Rack-->::smile:: "Towers and Cross bars"......
Thanks guys!!! Have a blessed Day!!!
~Tyler
When I looked into it a while back the main two choices I narrowed it down to were the Yakima Q Towers and Thule Traverse.
This was a while back and didn't sound like there were many removable racks for the second gen yet.
I think this is the thread of a member on here that used Q Towers:
http://www.clubfrontier.org/forums/f10/yakima-roof-rack-installed-50713/
And I think both brands have 20% sales a couple of times a year. Maybe around the end of May and end of November. Or you can check to see if there are any pieces in stock in Amazon Warehouse or when REI has their garage sales.
You can check out the autoanything site to see what's available. The part numbers should show the different components in the rack. ie cross bar length, tower part numbers and feet part numbers, if you want to end up trying to piece it together on your own.
1 - 3 of 3 Posts
