1 - 2 of 2 Posts
Woo hoo another issue. As the title says I can not separate the driveshaft flange from the yoke flange on my c200k. I have the dreaded CV joint driveshaft. Everything on the axle is unbolted including the 6 bolts for the yoke flange. As I try to pull the axle back the driveshaft comes with it almost as if something is still connecting the driveshaft to the axle yoke flange. Did I miss something here?
These two pieces are usually snug fitting. Also they tend to rust together. Just smack the edge of it with a hammer then pry it apart. May even need to spray some WD or something similar to penetrate the flange.
1 - 2 of 2 Posts
