1 - 9 of 9 Posts
hi!, I just bought a NP300 Frontier LE D23, and i´m looking to lift it, can I use this shocks that are for a nissan frontier D40,
Bilstein 5100 Front Height Adjustable & Rear 5100s
i´ll appreciate the help.
thanks
Take a picture of the front suspension. I do not know if they changed the suspension design or not.
What year is that NP300?
From Bilsteins website, they list this shock for the front. If the picture is what is realy looks like than I doubt the 5100 will work. Would also figure Bilstein would list the 5100 if it fit the NP300.
https://www.bilstein.com.au/bilstein-front-shock-absorber-for-nissan-navara-d23-np300-2015-current-be5-d626
thanks for your answer Nissan4Life.
my NP300 Frontier LE 2.5 is a 2018.
hope this photos help.
yes already look to that shock absorber, i read that the be5-d626 its for use with the oem springs, the 5100 adjustable for some lift already, the be5-d626 its for the Australian market, and the 5100 its for the frontier D40 in USA market.
that why bilstein USA not describe a NP300 truck.
regards
regards
So as far as I can tell, your suspension is identical to the D40's. I would think that the 5100 would work fine on your truck. Also know that the 5100 can provide lift. However the 5100 rears are only shocks.
thanks both for your answers it appears does not have instead has spring assy-leaf.
i will look a good deal to change them.
regards
1 - 9 of 9 Posts
