Hello,
I'm in the process of trying to add OEM power windows, locks, mirrors to my 2007 XE.
I have everything: OEM door harnesses, lock actuators, window actuators, switches... extra BCM connectors to de-pin.
The current problem is that my BCM is not outputting voltages needed.
BCM M19 pins 45 and 46 should have 12v going to the lock switches but show 0v with ign on or off.
BCM M20 pin 68 should have 12v out to the window controls. It has 0v out with ign on.
Interestingly pin 68 is populated with a blue wire, but all FSM docs say orange to the window switch. I can't find anything showing blue.
Strangely my truck has the keyless remote module present and wired from the factory. So I was hopeful I could just connect the required wires and the locks would work, but not so much.
Are the BCMs actually different internally or does it need to be programmed to "enable" these outputs?
I am open to buying a BCM from a truck with power accy.
My truck does not have an immobilizer so if I buy a random BCM I'm concerned it will no longer start due to the immobilizer? I am also slightly concerned with pin 68 already being populated.
I'm stuck...
I'm stuck...
