1 - 3 of 3 Posts
I found this forum because I have a problem with my 2000 Nissan Frontier V6 Desert Runner and Google sent me here. So how does this work? Do I make a new post after saying "Hey Y'all" or can I ask the question here?:hi:
You had to post here first in the new member section as a requirement before posting else where on the forum, so you got that part right. :thumbsup:
There is a first gen specific section (here) where you could post your question(s) if you want or post it here, either way works.
I'm sure some of our knowledgeable and friendly people will be able to give you insight into your issues.
Welcome aboard Clubfrontier.org!
Ok....My truck has an oil leak I told my husband its the main seal by the looks of things he says its the valve cover gasket. He tightened the bolts and still it leaks, so Im thinking of adding some stuff to my oil to see if that will stop the leak....can this stuff harm my engine?
It also lags in shifting could this be caused by the leak?
1 - 3 of 3 Posts
