I have a set of unused Hella 500 fog lights, BUT, they have no wires.
It is just the lamps with the couple wires sticking out of the back.
Question is, can I buy the rest of the necessary wiring and switch and have these as perfectly functioning lights or are they useless now or what????
Basically, can any half decent wiring/electrical guy figure this out easily?
(I know nothing about fog lights and/or electrical work)
you should be able to wire them up. here is a switch i used for some lights that fits right in that blank spot next to the cargo light if you still have the blank there.
I think it should work. Im not sure though. I used it for led underdash lights.
Scion OEM Style LED Rocker Switch
Yes, a half-decent wiring guy could figure it out. Any guy less than that, probably not.
You should really use a relay, so that the amperage from the lights doesn't have to pass through the rocker switch.
You will need:
  • 12ga primary wire
  • 15amp capable or higher "multiple purpose" relay
  • inline fuse holder with 15 amp fuse
  • switch of your choice
  • Various crimp terminals and connectors for easy wiring
  • dielectric grease to protect engine bay and light connections
  • heat shrink tubing to seal up all your connections and to make a clean install
If you want to get really creative, you can wire it up with an on-off-on switch -- so you can set them to come on with your parking lights, have them off all the time, or have them on manually.
^^^what he said.
