Been collecting suspension parts for years for my 2010 Fronty 4x4 V6 MT CC LB, FINALLY getting around to installing; bought Shrockworks front bumper, targeting highest suspension based lift possible out of adjustable 5100's anticipating significantly heavier bumper, trying to assemble front struts, being told by mechanic with fancy hydraulic spring compressor he's never seen a spring compressed so much in a strut setup, he claimed the coils were touching when compressed most (but not all) of the way. The lower spring seats are NOT install upside down.
Bought all new bushings top spring seat, spacer, upper isolator, and washers using correct parts, I'm suspecting the MOOG 81280 coil springs I received from RockAuto are wrong if anything??? It's like they have too many loops; I intend to count the number of helix's on my stock springs later today...
Does anyone have a picture of coil springs (appropriate for the suspension setup for my truck) compressed on a 5100 with the lower spring seat at highest lift position?
The only oddball part of this setup is I was frustrated by the impossible task of finding a lower coil spring isolator (go ahead and waste your time looking) I fabricated my own, I used pex tubing which has a ~1/8" wall thickness, even if worst case that extended the lower spring seat "height" another 1/2" I would not expect the spring to be so significantly compressed.
I'm wondering now if I should back off the adjustable lift height and also include a spacer?? I thought that is the BS way of achieving lift and I was doing this the proper way!!!
Thanks!!!
Thanks!!!
