so im not sure if this little problem is just how the truck is or if its something simple like a bad thermostat but my issue is ever since i've had the truck it wont blow hot air outta the heater when i start it first thing in the morning. I've even let it idle for almost an hour and the best ive been able to get outtof it was barely luke warm air, its only after i get it going down the road a a few minutes and only then can i get hot air. it seems like its not that big a deal but this time a year its kindof a pain in the a$$ when your defrosters wont do a darn thing for your frozen windshield.
its almost like only after you get it into gear will it start to run coolant through the heat exchanger, so like i said before im not sure if thats how they all are or if its an easy fix (thermostat?)
if any of you have ever had the same problem and found a remedy or if you know what might be wrong and where to start i would very much appreciate any feedback.
THANKS!!!
THANKS!!!
