1 - 20 of 24 Posts
06 cc 4.0 automatic
There is a plastic heater hose conector at the firewall that is also part of an aluminum pope that runs along the firewall and to the engine in the driver's side. The plastic is connector is cracked. Has anyone run into this? How did you fix it? I can't find this art online or even the proper name. I cant even check with a salvage yard. It's probably a stealer only part. I'm sure I can come it together, but was wondering what others have done. The part that's leaking is on the right with the hose going into the top. It also has the aluminum tide as part of it coming out the right side.
The plastic piece and aluminum tube is an assembly, it’s roughly $125 to purchase.
06 cc 4.0 automatic
http://nissan4u.com/parts/frontier/...body_electrical/heater_piping/illustration_1/
Aluminum Pope...
I think I saw them in concert once.
I paid around $60 with shipping for that pipe ,and the other plastic part through Nissan Parts deal.
06 cc 4.0 automatic
https://www.nissanpartsdeal.com/
Check this place for parts. I am replacing both of those plastic parts.
Mine was for my Pathfinder with rear heat and had a switch to divert water to the back and remember it was over $100.
Ah..did he say what he had ? I was assuming Frontier.
Yes, the Pathfinders w/ rear heat are expensive! Frontiers are too bad in comparison.
Hi All,
Just researching a broken connector myself. Is this the part you're referring to? Return side line of the heater core? Hose coming out of the top runs to coolant overflow reservoir?
305974
Discussion Starter · #15 ·
Very common spot they leak. I think some have devised there own part to repair it, but I think I paid $35 through Amazon for an OEM Nissan part.
Good luck.
Thanks for the reply. If I'm following the thread correctly, looks like part 92412-EA20 is the answer?
Good luck.
1 - 20 of 24 Posts
