1 - 10 of 10 Posts
I washed my truck and it is pretty damp all across the top of the headliner near the rear window. I thought it might be the third brake light but I silconed it and it is not the issue. Is this the rear window seal and if so how much will that run to replace?
Have someone else on the sprayer while you observe what's going on in the cab...
Explain how you "siliconed it" please.
I took the third brake light off because I noticed a few water spots on ym rear window after washing a few weeks ago. When I removed it I noticed the gasket was torn in several places. I peeled off all the loose parts but left the solid intact places. I then used kitchen/tub/tile white silicone and spread it all over the third brake light mating gasket places and reinstalled.Did I do something wrong?
I had the same spots and did the same fix about 9 months ago and haven't had any problems since. I couldn't find the gasket by itself, iirc. Or maybe I did and went with the caulk for another reason.
1 - 10 of 10 Posts
