It's possible that you lost 4th gear due to transmission damage when the hose blew... fluid starvation is not good.
Heath
Heath
It actually stripped instead of breaking completly. I shut the truck off at work and when I got ready to leave, it wouldnt start.The timing belt broke without any valve damage, thats hard to believe.
It happens more often than you might think. If you remove your timing belt and CAREFULLY turn one of the camshafts, you'll find that our engines have a tolerance somewhere around 45-60 degrees +/- TDC @ the camshaft. (I wish I could give a more definitive number, but I didn't want to push my luck). Also, valve reliefs in the face of the piston limit shear stresses on a valve in the event of contact, which mitigates some of the risk of bending/chipping/breaking it at low engine speeds.The timing belt broke without any valve damage, thats hard to believe.
