1 - 18 of 18 Posts
I did the mod a few months ago out of precaution. After reading so many post regarding the blown axle seals from the previous gen I didn’t want to take any chances with mine. Not saying it would or wouldn’t happen. I don’t do any off-roading or the like, but who’s to say it can’t happen to our 3rd gens? I used the Alldogs off-road breather for mine and placed it behind the taillight.
Tire Automotive tire Font Tool Rim
Unnecessary unless you get your diff submerged a lot. My gen 2 made it 260k+ miles without it and didn't have any issues. Lots of winters too.
Just using anecdotal evidence like yours, you are outnumbered. TRUE that submersion can be a trigger, you don't need to be driving through water to have an issue... and it might only take ONCE. Of all the things one can do, this is one that is on the easy scale.
Do others never have an issue? Sure!
Beg to differ. I may be outnumbered on this forum but majority of Frontier owners are not represented here. This is an enthusiast hangout and the members here are a fraction of the Frontier universe, and majority of that universe are driving around in multiple generations of Frontiers (and Titans, Armadas, Xterras, Pathfinders) without a worry about diff breathers. I am not aware of large numbers of diffs blowing up because of failure to relocate the breather either. It is actually very unlikely that you will have an issue even if you don't do it, most people don't.
True... but I'll not promise results for another. It isn't my truck they are driving.
What CAN happen has examples out there. More might have been in warranty or fixed without complaining online. Note.. this is not merely a relocation IMO. I eliminated the stock valve, most do.
This is right up there with all sorts of betting the odds mods or preventative maint. But cheaper. Coatings, PPF, favorite oil, catch can, etc.
Last point, this puts vent based failures we can mitigate at as close to 0 as it gets. Creeks and boat ramps are a thing... floods. Grime. It's one thing to have odds in your favor (we do), another to shift them further for a few dollars. If it was costly or difficult I wouldn't bother.
2022 Nissan Frontier Pro-4X, Baja Storm, Everything under the sun
I just change the stock breather every 3 oil changes. It's a 5 minute job. Anyone know if the breather p/n is the same as the 2nd gen?
Must be. I don't see Nissan carrying over dang near everything from the gen 2 chassis except for the breather. But then, again now that I think about it, this is exactly the kind of thing that they would do.
Plenty of threads 2nd and 3rd gen about this topic and how to.
I personally did this as Nissan has the front diff already vented to an open ended hose, and I figured I would do similar as the rear is used all the time. After removing the stock breather and hearing the built-up pressure release from the rear diff, was just confirmation to me that the rear could benefit from a more free breathing vent. This was only done after about 1k miles on a new truck not even ridden hard yet or on trails. I don't plan to do many deep water crossings, but since Nissan used a longer hose for the front, I too added the hose up for the rear. $30 in parts, half hour time, and peace of mind for me.
I too thought about just replacing the stock breather every year as preventative maintenance, but the hose route seems more viable should that stock breather seize. It's not the best design IMO, and just because one can wiggle the the metal cap, DOES NOT MEAN IT IS OPERABLE.
Just my two cents.
I was going to ask, why would I need a rear diff breather. If you are submerging that deep often enough, many more components need equal attention and concern.
Actually if one goes in water to say launch a boat or a deeper than normal road puddle, the breather height is kinda low compared to most stuff. The axle and brakes are the only other components that are really susceptible to water issues. Sure, you can go deeper, but it's been discussed, the drawing of cool water into the diff when it's warm/hot is a possible issue.
Again, I don't go into water that is three feet deep :p, but just wanted the diff to breathe better. I didn't care if I had a "snorkel" for the diff. But that's me. ;)
  • Helpful
Reactions: Slavic Boer
Discussion Starter · #13 · (Edited)
Of course if you have water above your axle your going to have more problems to worry about then this. My idea is, regardless of where or how you drive, I’d rather be safe than sorry and not have to worry about replacing my rear axle seals sometime in the future because I didn’t do this mod earlier.
Of course if you have water above your axle your going to have more problems to worry about then this. My idea is, regardless of where or how you drive, I’d rather be safe than sorry and not have to worry about replacing my rear axle.
Or the seals ;)
Reactions: Turbo Actual
Discussion Starter · #15 · (Edited)
Or my seals. 😅 I think of it as preventative maintenance. I see relocating the breather to a better spot, the same as bypassing the lines from the old SMOD days.
2020 SV 4x4
I say totally necessary. Counter-single data-point: my Gen2 Nismo made it 126K and 3 times it needed new seals. Never submerged, lots of dry dirt roads and also winters in CO. They went once well before 36k, then 80k then just after 100k after my extended warranty ran out. I sold it at 126k. Since my 2020 has the same rear axle I did the breather mod first thing based on my experience with my 2008.
1 - 18 of 18 Posts
