1 - 11 of 11 Posts
I got these shackles at my local auto shop today.
has anyone used these
or will these even work?
they are superior automotive "lift kit" shackles
they are pretty big
there the size of my forarm from my elbow to my wrist..
let me kno..
thanks yall bwbolt
bump
Had em on my old S-10 for about a week, then I came down on a rock an bent the sh*t out of one. I'd stay away from them if I were you.
im posting the pics on my profile the install went well except i had to buy nylon spacers to make the fit between the bolts and the bushings tight. i posted it in my DIY install gallery. i got just over an inch of lift in the rear.
my local auto store sells these shackles too. does anyone know the amount of lift it provides at the lowest and highest setting?
I got them for my 01 , would not work doing to the top bolt being twice as thick and pressed into oem shackle.......Not removable and not worth the 2 inch , will get real ones later..
I have a set of SLR shackles that are 1" longer than stock for 1st gens. PM if interested
with the top bolt thing all you have to do is use nylon bushings from your localhardware store and the bushings weren't pressed in. the bushings on my 03 mine slid off with a little help from a flat head
1 - 11 of 11 Posts
