I found this while searching for lifts. What does everyone think?
www.4x4parts.com
Frontier Suspension Package
Thinner, rounded edges for better flexibility. Easy installation. Extension of ABS line and brake lines is recommended. Includes longer rear shocks. These coils replace your factory coils. Made to work with stock or after-market shocks with the same amount of travel. Made of high quality steel using cold-wound process which virtually reduces settling or sagging. Provides improved support for vehicles equipped with a winch or heavy bumper. Will not require removal of upper ball joint to install. Requires coil compressor for installation. Unlike spacers, these coils will NOT cause contact of upper a-arm with upper coil bucket. Unlike spacers, these coils compress so that wheel travel is not lost by the amount of lift. Coils keep the factory CV angles and steering components within factory design parameters. Powder coated black for longevity. Have not been tested with spacers so they are not recommened for use with spacers. Can be used with drop down design suspension lift for additional lift. Spring rate is increased marginally which keeps the ride quality comfortable. Suspension lift includes two front coils and two rear add a leaf. Amount of front lift will be limited depending on which coil over shock you are using. Different models have different shocks so degree of lift may vary. Includes 2 Rancho RS5000 rear shocks.
Price - $275.00
www.4x4parts.com
Price - $275.00
