I saw somebody try that trick on a VG engine and they ended up breaking the starter housing. If you don't have access to an air impact gun, the best and safest way is probably to use a small tie down strap and run it from the frame, around the balancer a few times and back to the frame. Then use a breaker bar and socket on the bolt.
