I finally got my radio pretty much installed. I have a General License for HAM (W6THO) and I do Search and Rescue. The radio will get used a lot more on SAR than HAM. Criteria for a radio for those interested: (1) dual band VHF, UHF; (2) 2 channel monitoring; (3) potential for cross-banding for relay work; (4) a small footprint; and (5) a good quality radio. The radio I installed is an ICom IC-2730A. This fits all of the criteria above.
Prior to doing the install I did the MARS mod on the radio to allow transmission on the full VHF / UHF range. This is necessary for Search and Rescue, which relies on commercial band frequencies.
For the install, I ran 10 gauge wire off the battery (fused at 15 amps) and in through the grommet hole that is on the driver's side next to the main wire loom that goes through the firewall.
The wiring goes to a relay that is bolted to a convenient bracket up under the dash. The relay is powered off the same line as the 12V outlet. This way the radio is only powered when the key is on to avoid the accidental dead battery from not turning the radio off.
The 10 gauge then goes under the driver's side door sill and under the driver's side seat. I have an LF-1 OEM noise filter installed just before the radio. The radio body is under the seat, now just in place with friction -- some feet affixed to the bottom to give a little space above the carpet and keep the radio from moving.
I'm not certain where I want the control panel long term. As a trial mount I had a small base 3D printed. This puts the panel at a 30 degree angle and accommodates the curve in the console. This is affixed to the console with two-sided body trim tape.
The mic comes up from under the seat. I will use a piece of velcro to allow the mic to be affixed to the side of the console -- I really don't like the hangers as it's more of a hassle to get the mic on and off.
The antenna is on a mount that I made that clamps on to the front of the bed and hovers above the tonneau cover.
The antenna runs through the rear cab vent, along the rear door sill and under the driver's seat to the radio body.
So far I'm happy with the install and the radio.
