1 - 3 of 3 Posts
Just installed all new wiring and lights on my boat. Found out the ground on my hitch wiring mounting up on the body is no good. Question where are grounding points on my truck. There is one from the battery to body and one on alternator. Is there a how to on grounding kits. Could the body not be grounded for some reason with sercurity features.
Man, I'd triple check that ground connection. If the frame wasn't grounded, I'd think you'd be seeing some serious other electrical problems.
Maybe bring the ground all the way up to the actual cab body in case somehow the frame or truck bed aren't making metal on metal contact with the cab body. I kind of doubt that though. If that isn't it, I don't know what to tell you. Maybe a faulty harness.
Perhaps someone more knowledgeable can explain further.
1 - 3 of 3 Posts
