How often should i do this? Fixing to to rotate my tires (3K miles) and wasn't sure if i needed to do this aswell, is it just a couple pumps from a grease gun on each one? thanks for the help again guys and gals ;)
Thanks! How many pumps usually? I Dont want to blow out any seals.
For the upper control arm bushings, i pump until i see some grease coming out from the sides, usually 5-6 pumps.
For the Ball Joints, im contantly checking the rubber housing that holds the grease to make sure its full but dont over fill it because it will tear. Just enough that you feel it firm then stop.
