1 - 9 of 9 Posts
Well my BFG's needed replacing so I decided to try a new brand. I went with the Procomp Extreme AT's at 31x10.5x15. So far so good. Same saize as the BFG's but had to do some trimming because these rubbed a bit.....weird
look good
How's the road noise?
a bit noiser but i think it's due to the new offset from the wheel. The tire is exposed past the fender so I think that is why I here it more.......If I wanted quiet I would have bought a hybrid...lol
how do they do off road
good reviews but I haven't had them off road yet. I will work on that this weekend. They're a directional tire so you can only rotate front to back but I'm pretty good about rotating.
Well at first I tripped out because they're the same size as my BFG's and those didn' rub. I have a 15x8 inch rim now instead of the stock 15x7. I'm also running a 4" backspacing instead of the stock 5.25. So the wheels are sticking out further. At full lock they would rub my mud flaps....that is before I took the dremmel to the flaps. Now no problem
1 - 9 of 9 Posts
