1 - 4 of 4 Posts
i went and got three sensors on ebay (two camshaft and one crank sensor),as soon as the engine cools,just drove in from town so the engine is a bit warm then i will reset the computer and we shall see if it was a waste of money. they even came early,not suppose to be here til friday.::smile:: we shall see and pray.
Is the CEL coming on?
Are you getting codes P0335, P0340, P0345?
If yes then change the sensors.
If not then why buy the sensors?
yes the cel was on so i went on ebay and got the two cam sensors and the crank sensor. the drivers side cam sensor was bad so i changed it. not sure about the other two,usually if one goes bad the other two are not far behind since they were put in at the same time.
I need to buy sensors to keep as spares.
I will probably buy OEM.
1 - 4 of 4 Posts
