1 - 20 of 63 Posts
I just installed the Off Road Gorilla hood strut kit,
(like the one Raine installed) on my Desert Runner,
and noticed that when the hood is shut, the driver
side of the hood doesn't close flush with the fender.
It actually sticks up approximately 3/16". It's very visible.
:frown:
The passenger side closes perfect. Trying to figure
out what might cause that - maybe a bad strut?
Mdlweb
you have a photo by chance?
I have them on my truck and do not recall any fitment issues with my hood. I think you can see the strut a little bit in the body line between the fender and hood if you look straight down into the gap...
You remembered to remove the old hood prop rod and its plastic holder clip, right?
Reactions: tytrim89
Mine fit and function perfectly.
Discussion Starter #5
I'll post a couple of pics later this afternoon when I get home from work.
Probably around 3:00pm Pacific time.
I did remove the old hood prop, but maybe I left the plastic holder
attached to the inside - Great thought! Thanks Skibane!! I'll look at that.
I love this forum..... I always get responses.....
Mdlweb
I'm sure you checked but the mount on the hood might not be all the way tight. That would allow the install but if it's loose it may not be all the way flush.
Sent from my Pixel 2 XL using Tapatalk
Discussion Starter #7
Thanks everyone for all the responses!!!
Skibane figured out the issue. I forgot to remove the plastic holder
clip that held the old hood bar in place. SO.... the strut kept hitting
that piece and wouldn't let it go all the way down.
Thanks Skibane!
Mdlweb
I did the same thing when I installed mine. :mrgreen:
Let the hood down gently, and noticed that it didn't want to close like it should... :rofl:
Thanks Skibane!
Mdlweb
That's good news! I'm going to install my struts tonight and your post was making me a bit nervous.
Discussion Starter #10
Everything is good! The strut was landing on top of the
little holder clip, ('U' shaped plastic piece) thus not letting it close all the way.
Don't forget to remove it. Just squeeze it and pull, and
it comes right out. OH.... Love JL Audio stuff.
T
Guest
Anyone get a set of install instructions with their kit from OffRoadGorilla?
T
Guest
Got it. Did your's make noise? the hydraulics making a swoosh sound when opening?
Mine sings the Star-Spangled Banner
Reactions: tytrim89
I hydraulic strut making noise when you retract and extend it? Surely not.
Sent from my XT1635-01 using Tapatalk
T
Guest
I don't think normal is the sound of a jackhammer as it raises and stops then raises and stops. The hood should raise in a smooth manner.::grin::
Check the rear corners of your hood near the windshield/hinge, chances are one or both are rubbing the top of the fenders at that area.
I'm just giving you some flack. Haha, I'm glad you saw the sarcasm.
Yeah, they should open smoothly.
1 - 20 of 63 Posts
