1 - 12 of 12 Posts
Here we go:
EXTERIOR...
Shrock Engine Skid
Shrock Transmission Skid
Shrock Transfer Case skid
Shrock Diff Protector
Shrock Rear Bumper
Relocated Trailer Plug
Custom Corner CB Bed Mount
INTERIOR...
Cobra DX 19 CB
Custom holster for center console
Added always-on 12V power to rear center console
Tailgate Lock Mod
SUSPENSION...
front: 2" OME SD Lift Coil and Sport shocks
rear: 2" PRG/Deaver 2 leaf AAL with Bilstein 5125s
And many more to come...
Back when I got her end of August 15 and now...
First mod was the tailgate power lock, I don't have many pics of that one..
The trail took a toll...
Next up I installed an unswitched rear USB charger and cigarette lighter...
with a lighted switch so I could make sure it doesn't drain power...
Next was the trailer connection relocation to rear bumper. I used all stainless hardware.
This weekend, I installed a holster mount...
And today I installed a 4' Firestik antenna....the rest of the system is pending this week....
Best put a tennis ball on that 'stik. Ask me how I know...
Discussion Starter #4
Got around to installing the actual radio a while back...ran the coax under the console, under the rear seat mats, and through the rear cabin vent to under the box. Power is hooked up to a 12v outlet via a molex connector.
looking good! Love that XDM - I have a 3.8" XDM full size 9mm, might look into a holster mount like that as well!
Discussion Starter #7 (Edited)
You made me do a double take. The pistol in the pics is actually mt Bersa UC Pro in 9mm. I do own an XDm as well, so that's creepy.
EDIT: just noticed one of the four pics I took did have the XDm...my bad.
Neither. At high speeds the antenna will "dance" and smack the bedrail cover.
At speed it seems to be at a 35 degree angle to the tailgate, maybe its difference in the spring used?
Just added Shrock diff cover and t-case skid this weekend..
You have your XDm in this pic http://i1058.photobucket.com/albums/t414/3inSlugger/Truck/Message_1460301175099_zpsdysmoe5z.jpg
Discussion Starter #11
2020 Update!
Pics coming soon!
EXTERIOR...
Shrock Engine Skid
Shrock Rear Bumper
DIY Mudflaps
Gorilla Hood Strut Kit
Amazon special under-hood light kit for those night worktimesf
INTERIOR...
Cobra DX 19 CB
Tailgate Lock Mod
Carrhardt Front Seat Covers
SUSPENSION...
Not Anymore! now it is Titan Swapped:
SPC Uppers
Nisstec Half Axles
AcDelco Titan Lowers
2.5 Radflo IFPs (See note below)
PRG Outer Tie Rods (these are awesome BTW)
Bilsteins 5100s in rear,w/2-3" Shackle and Bora Wheel Spacer (still have the AAL)
Also got a PRG rear diff cover installed
312969
312970
Things in the works:
Fixing the painted grille pieces
Shrockworks radiator, gas tank skids, and front bumper on the way. Got a Smitty X2o 10k winch for Christmas.
Discussion Starter #12 (Edited)
Note on the Radflo Install:
Buy some 14 diameter, 80-90mm long bolts to replace the lower shock bolts. Nissan uses a tapered stock bolt which do play nice (or quietly) with Radflo's two-piece steel bushings. I had the "Radflo-clunk" until swapping these bolts out today. EDIT, still appear to have the Radflo clunk.
1 - 12 of 12 Posts
