1 - 4 of 4 Posts
I need to get behind my glove box to run a wire. Can someone give me a quick “how to” on taking off the glove box?
Thanks!
Senior Moderator
If by glovebox you mean the lower box, I just did this yesterday. You have two options:
1. With the door open, squeeze the sides inward and the door should fall open. You'll see the two tabs that need to "come in".
2. If #1 doesn't work for you, which it didn't for me. It's 5 screws. Two below the door on the outside, 2 on the inside behind the door on top and a 5th screw "hidden" behind the plastic strip between the box and the door frame. It's easy to get to with a flathead screwdriver.
1 - 4 of 4 Posts
