1 - 3 of 3 Posts
Does anyone know how to replace the center console gear shift indicator lamp on a 2013 Frontier? Mine is blown out. I did a search but cannot find anything.
Thanks.
Should be fairly easy. Check about halfway through this post if you need some visual references.
Slide the silver collar down on the shifter to pull the pin and pull the shifter knob off. Pop out the cup holders and face plate around the shifter. A couple tabs to release the indicator face plate, pull the bulb housing and replace the bulb. Bulb size is a #73 if I recall correctly.
2016 Frontier SV 4x4 Crew Cab
interesting. mine doesn't have a light on the shifter or around the keyring. guess Nissan went cheap on those later too.
1 - 3 of 3 Posts
