21 - 23 of 23 Posts
First off the rear ends are all dana 44's and the gears that came with the auto use the small carrier so:
You should really check out the WHAT AXLE TO I HAVE? Sticky in the Axles subforum..........all the information is already there...and correct :thumbsup:
cool
Thanks for that info. Now when I checked mine says CA36
So I get the C200 and 3.69 gear whats the A Auto trans?
I am now looking for the gears from an XE manual at 4.083
Do you know if the carrier bearing that hold these gears for the C200's are the same size? So I could just switch the spider gears?
21 - 23 of 23 Posts
