Idk what I’m doing wrong. Filled up yesterday, at 276 miles. Everything adds up, I was average 17mpg that tank, had about 80 miles left based on the gas it took and gas that was already in the tank. Which would have me hitting 350 miles on a tank, but that’s running it out of gas.
it's not an exact measurement. it won't be perfect. it's just a guideline to use....basically a 2nd fuel guage. you have the analog guage and the digital guage dte. neither one is perfect. they just get you close.
if you want exact set your trip meter or use the odometer and count the miles. the dte measurement and trip or odometer mileage will not change at the same rate.
i had an old 1988 toyota truck and the fuel guage stopped working. i would just fill it up with gas every 250miles using the odometer. that way i knew i would never run out of gas. it could probably go much further than that but there's no need to push the limits. just fill up more often and avoid being stranded on the side of the road.
...but if you really want to know for sure. fill the truck up with gas, fill up a can of gas to use when you run out of gas, set the trip meter or write down odometer number and drive until you run out of gas. that's how many miles you get per tank on average.
it's really not good to run a vehicle out of gas though. it should be avoided.
