Hi I'm from St.Simons Island Georgia and trying to find info on my 2002 Nissan XE Frontier .
The system want charge the battery ( Has new alternator , Belts and battery )
Belts lose ? Bad battery cable ??? ......
Thanks for any help !!!
Rick
Welcome to club frontier.
Have you checked the ground cable to be sure there isn't any corrosion on the other end?
Is the positive cable good at the other end too? Have you tested the new alernator to be sure it's not a defective replacement?
Have you checked the alternator fuse under the hood?
Have you checked the voltage at the battery with the engine running? What kind of voltage are you getting?
What about the voltage at the alternator itself?
How tight is the alternator belt?
Is the battery any good? Check the battery voltage, it should be over 12 volts with nothing running. Engine running the alternator should be putting out 13.8 to 14.2 volts on a weak battery.
If the batter is under 12 volts - battery is bad
Alternator not putting out 13.8 and all your connections are good - bad alternator
Thanks for the Help !
It turns out to be a lose Alternator belt ...
Thanks for everyones Help !!!
Rick
