1 - 10 of 10 Posts
2006 SE,
4.0L
6 speed man
157K
Questing on fueling.
I've had truck for about 8K. Has always ran like current so I can't compare.
No codes
Cats are new
Compression good all 6 cylinders
plugs newish
air filter good
all stock/no mods
Idle 675
no hesitations
MPG- 20 highway
Symptoms
accelerates flat 2000-3000 RPM. Feels like it has plenty of torque but adding fuel doesn't seem to react how I feel it should. Like the truck is forgetting i'm the boss and gives the fuel what ever it thinks
Like it lacks the horses.
I can pull a small trailer with no problem but feel its the torque doing the work if that makes sense.
I realize its a heavy vehicle but confused as to its lack of response.
Maybe it needs to be remapped?
I don't know if Nissan has these trucks run like this for better fuel economy and its just a nani control.
I would check the fuel rail pressure but that is a project with no quick access.
Any ideas what I should be looking at?
Same clutch? I read here that if the clutch job is botched, the truck will bog. Not sure why.
Did '06s have WOT restriction?
Yes. Sounds like this is the issue. The truck will not provide 100% open throttle until ~40mph (I think that is the speed). I forget the exact throttle percentages it allows at what speeds but it's something along the lines of 40% throttle to 20-25mph and 60% throttle from 25-40mph. Don't remember the exact numbers but that is the gist of it. If you don't like it, go buy a plug and play tuner and disable it.
Ok that makes sense.
That's frustrating. These trucks need to have an option to shut these nani controls off.
I would imagine tuning it without the restriction would feel like a new truck.
Going to look into that.
Thanks
I had one for a while and it definitely makes for a more "spirited" driving experience. Decided it really wasn't something I had to have though and ended up going back to stock tune and sold the programmer. I haven't missed it since. Really depends on your preference.
Not really. Lost slightly over 1 mpg maybe. I was just cleaning out the garage and saw the tuner laying there in the box and decided I didn't need it so I just tuned back to stock and sold it for some extra cash.
Yes, HitecRednec, I can feel an extra push come on line between 35 to 40 mph in my '06, much like a turbo that has spooled up and suddenly adds boost. I've never minded this "feature". My truck feels plenty quick with the 6-Speed and perhaps the "feature" helps preserve the rear end from a bit of mechanical punishment.
1 - 10 of 10 Posts
