I have a '16 Frontier CC LWB, When the light comes on for the fuel tank, I can only put in about 15 gallons.
I looked at the tank the other day when I was under the tank and it looks to be sagging in the middle. Both tank straps are fine, but the unsupported part in the middle is lower by about an inch.
Anyone have any experience with this.
If you can, take a look at your tank and see if it is also sagging.
Thanks
Josh
sounds about like mine... if the unprotected tank bothers you, pick up a tank skid from hefty or Schrock... with some looking you might find others... or if you're handy or have a friend that is, you can cut & bend up one yourself... The tank skid is pretty simple & straightforward.
I wouldNot suggest the OEM tank skid as its just as expensive as the aftermarket offerings (unless you find someone willing to let it go for a song) and they're just 1/8th stamped Aluminum (maybe even 1/16th... same gauge as the front radiator "skid plate") fine for sticks & gravel... not for offroading.
What you described is what I've had on all my frontiers past and current, enjoy the truck.
