1 - 2 of 2 Posts
On my 03 frontier the fuel filter is mounted to the right frame rail, near the fuel tank. Just go to auto zone and get one, less than 20$, after you get one you wont have any problems finding your old one. Remove the fuel pump fuse from the passenger compartment fuse panel. Crank the motor it will sputter out quick. This relieves the pressure from the fuel system. When you disconnect the filter your gonna have some gasoline coming out the hose. Be prepared, rags oil pan no smoking you get the picture. You should easy do the job in a hour. GOOD LUCK Real important maintance item cause a clogged filter can ruin a fuel pump(expensive,pita to change) or make the truck run like sh!t.
1 - 2 of 2 Posts
