1 - 1 of 1 Posts
Hey guys, selling my 3 Dell U2414H 24" monitors, I am including an Ergotech Triple stand with desk clamp, or base stand at no additional charge..
Little background on these, these monitors were cherry picked from about 12 panels that I received - they have the least amount of backlight bleed (which is almost nothing) from the bunch, all rate 99-100% sRGB (Spyder4Pro colorimeter verified), and are all A03 firmware so all the Displayport issues, and other quirks have been worked out. These are 24" (23.8") IPS LED panels, and are excellent for editing or gaming, or whatever task you throw at them. These monitors also do MST (multi stream transport) so it only takes 1 Displayport cable going into your videocard for all 3 monitors to be hooked up [you daisy chain them together]
Includes Power cables, Displayport cables, and USB cables for them. Clamp for the triple stand is currently clamped to a 1" thick desk, it can go thinner, or thicker, just make sure your desk can withstand about 70lbs in gear.
Additional measurements: This setup is 64" wide. and about 20-24" tall.
Looking for $650 shipped for all 3+stand, CONUS only - Will ship outside of CONUS at buyers expense.
Amazon Links for your convenience:
Monitors: https://www.amazon.com/Dell-UltraSharp-U2414H-Screen-Monitor/dp/B00GTV05XG
Stand: http://shop.ergotechgroup.com/100-series-stands/
The stand is around $150-200 depending on who you get it from, usually comes with the large steel base which is U shaped, this comes with steel base and the desk clamp (clamp is like $40 extra from Ergotech)
1 - 1 of 1 Posts
