1 - 9 of 9 Posts
SOLD: Stock Leaf Packs with Deaver AAL Attached.
I have my Stock Leaf Packs with the Deaver Add-A-Leafinstalled on them. These were installed on my truck for about one and a half years and provide 1.5" of lift. I switched to a full Deaver Leaf Pack and have had this rear suspension setup sitting in my garage. I have removed the overload leaf from these packs as I feel they are unnecessary with the addition of the AAL.
I am asking $200 for both Leaf Pack sets for a local pickup from 19380 or $200 + Shipping for a non local purchase. They were freshly sanded, cleaned and repainted with black Rustoleum. Purchasing this will save you the hassle of installing the AAL and OEM Leaf Pack otgether with a new center pin. Also, this kit does not require the installation of shims, which makes it a lot easier.
Discussion Starter · #2 ·
This is a great mod for anyone who is looking for a starter lift for their truck. This is a great addition to a spacer lift up front.
Also, this will save you the trouble of having to combine your stock leaf pack to a new AAL kit and install a new center pin because it is already done!
PRG has the AAL Deavers for 149.99 at prgproducts.com.
None the less, not a bad deal considering its both already done.
The OP didn't state this but that leaf pack is off an Xterra.
just curious these are off an xterra right will they fit a frontier ?? and since a x is spring under and the fronty is spring over wont they give way more lift than 1.5" because of the arch in the x springs
didnt steve47 rebuild his rear leaf pack with xterra springs?
1 - 9 of 9 Posts
