Take over payments ZERO DOWN..... I Would only deal locally, I need it sold ASAP... Pls call 210 215 4804 ask for Juan
Must have GOOD CREDIT to be able to finance the balance which is less than $12,000
some examples of payments option with a bank
Auto loan amount: $12,000
Auto loan term: 5yrs
Interest rate: 7% per year
Monthly auto loan payments: 230.22
or
$220 at 4 % per year
The car is in very good condition both mechanical and appearance... We dont need to cars in my family, my wife is not working and I work from home so with are ok with one vehicle. My other ride is a truck, so unfortunately the SE-R has to go
... The car is real fun to drive, the stereo sounds awesome, the seats are very comfortable and 3 adults EZ fit on the back seats... My wife was the daily driver for the car, most miles on the car are just from her going to her work back and forth...
Here some info on the car
Miles 19,200
FULLY LOADED : Rockford Fosgate audio ($750: eight-speaker 340-watt audio system with 6-CD changer), sunroof ($750); XM Satellite Radio ($300); keyless entry and ignition ($250); floor- and trunkmats ($165) Smart entry
Good Gas saver: 24mpg city and 32mpg Hwy
2007 Nissan Sentra SE-R
POWERTRAIN/CHASSIS
Drivetrain layout Front engine, FWD
Engine type I-4, aluminum block/heads
Valvetrain DOHC, 4 valves/cyl
Displacement 151.9 cu in/2488 cc
Compression ratio 9.6:1
Power (SAE NET) 177 hp @ 6000 rpm*
Torque (SAE NET) 172 lb-ft @ 2800 rpm*
Redline 6200 rpm
Weight to power 17.6 lb/hp
Transmission Cont variable auto
Axle/final-drive ratios 2.69:1/1.15:1
Suspension, front; rear Struts, coil springs, anti-roll bar; torsion beam, coil springs, anti-roll bar
Steering ratio 16.4:1
Turns lock-to-lock 2.9
Brakes, f;r 11.7-in vented disc; 11.5-in vented disc, ABS
Wheels 7.0 x 17 in, cast aluminum
Tires 225/45R17 91V M+S, Continental ContiProContac
DIMENSIONS
Wheelbase 105.7 in
Track, f/r 59.5/60.4 in
Length x width x height 180.1 x 70.5 x 59.5 in
Turning circle 35.4 ft
Curb weight 3112 lb
Weight dist., f/r 63/37%
Seating capacity 5
Headroom, f/r 40.6/37. in
Legroom, f/r 42.4/34.5 in
Shoulder room, f/r 56.9/55.1 in
Cargo volume 13.2 cu ft
TEST DATA
Acceleration to mph
0-30 2.6 sec
0-40 4.0
0-50 5.5
0-60 7.4
0-70 9.6
0-80 12.4
0-90 15.7
Passing, 45-65 mph 3.7 sec
Quarter mile 15.7 sec @ 89.9 mph
Braking, 60-0 mph 133 ft
Lateral acceleration 0.79 g (avg)
MT figure eight 28.3 sec @ 0.59 g (avg)
Top gear revs @ 60 mph 1900 rpm
CONSUMER INFO
Stability/traction control No/no
Airbags Dual front, front side, f/r curtain
Basic warranty 3 yrs/36,000 miles
Powertrain warranty 5 yrs/60,000 miles
Roadside assistance 3 yrs/36,000 miles
Fuel capacity 14.5 gal
EPA city/hwy econ 24/33 mpg
Co2 emissions 0.74 lb/mile
Recommended fuel Unleaded regular
You can find more info on the car here 2007 Nissan Sentra SE-R - Long Term Test Verdict of Nissan's Sentra SE-R small car - Motor Trend
or
Miles 19,200
POWERTRAIN/CHASSIS
Redline 6200 rpm
DIMENSIONS
Wheelbase 105.7 in
Curb weight 3112 lb
Seating capacity 5
TEST DATA
Acceleration to mph
0-30 2.6 sec
0-40 4.0
0-50 5.5
0-60 7.4
0-70 9.6
0-80 12.4
0-90 15.7
CONSUMER INFO
