1 - 20 of 36 Posts
A while back I was on this website and read a post about a company that makes the stock frontier roof rack from nissan for a fraction of the cost. So I checked it out (Powerfuluk.com) and I was impressed. You can order an exact replica of the stock rack or a chrome one for a fraction of the cost. It uses rivet nuts and is very sturdy and easy to intall. I recomend it to anyone that has always wanted that roof rack but did not want to pay nissan $1500 for it! Reply if you have any questions about it.
hmm, interesting find but the stock rack doesn't connect with rivets.
he said "riv nuts" theyre basicly nut inserts that you pop rivit into metal to give a threaded insert into anything...
· Super Moderator
^-- Correct - but the factory rack has the backing plates/braces that you install and are threaded.
I wonder how much weight this rack is supposed to support since it doesn't attach like the OEM one?
where can you get these?
· Super Moderator
McMaster Carr has them but you also need the install tool (for most types), best to have an air tool too if you are installing a lot of these.
There are quite a variety of styles of these and many applications for them.
McMaster-Carr
We use them fairly often where I work, they come in handy for prototyping, one offs, etc..
correct Todd, the kits up to about 1/4" are cheap and easy. But when you go above that the tool and kit gets expensive. I use just the rivnut inserts for 3/8" bolts in steel. I tack wled the nut into the hole, then thread a bolt into the inserts and tighten to crimp without buying the tool to do it. And on the rack. as long as the mounts are the same I would get the factory plates. If not...well depends on the weight you wish to carry and how loaded
Discussion Starter · #10 · (Edited)
I know the stock one does not use rivets. That is why the one I bought is possible to put on my King Cab. It may not be as strong as the stock rack, but it looks exactly the same
After the Paypal exchange rate, shipping and a couple of tools it was $540. There is no allignment sheet. YOu just put the assembled rack on the roof and mark the holes that way.
ohh wow, there are actual kits?
i need to find these because im putting a roof rack on my KC gen 1
check online with harbor freight, or I think I got mine online with Eastwood
mine is factory, I was referring to other uses
I just installed the Powerfuluk.com roof rack on my 06 Frontier CC, the Install was REALLY EASY it cost me $565 to get the Rack from Powerfuluk.com. As for the Structure integrity of the Rack I would say it so take most of you typical loads. The only real difference between theirs and the Factory one is the Rivitnuts so If you not convinced with the rivitnuts integrity just buy the factory foot plates to use instead. Though this will make your install more difficult.
When I bought my Frontier SE in the end of June, I had to get a roof rack for it. Searched varies junk yards (well called them), internet, ebay, etc, and then when I was set on the Powerfuluk one, I found one in the classifieds here. Other than good timing, the Powerfuluk one is probably the one to get if noone is selling here. All the junkyards wanted 1/2 of new so they are more expensive.
There's a very good tutorial on how to install with brackets here.
OEM and Aftermarket Roof Rack Modification with Truck Cap
I have a 2011 Crew Cab Pro-4X and I ordered a LEER XL Cap for it. The roof rack options for this brand of CAP was THULE systems. With the OEM Nissan Rack side bars running parallel with the truck and the THULE bars running perpendiculat to them - it just doesn't look right to me! SNUGTOP makes a cap with what looks like NISSAN OEM bars on it but, no dealership this side of the Mississpii River and they want $750 to ship it to me sight-un-seen! No way!
So, what I'm thinking of doing is buying a "POWEFUL UK" knock-off ($about 400 + shipping) of the OEM rack kit and installing it thusly (if "thusly" is a real word?):
1). Disgard the front mounting pads.
2). Remove the end caps of the OEM rack on my truck.
3). Assemble the POWERUK rack with cross bars installed and place on truck cap roof for sizing reference. Place the side Bar with the aft mounting plate on the CAP as far back as allows the rear door to fully open with out hitting it.
4). Then check to see how much of the forward end of the side bars overlaps the rear end of the OEM roof rack tubes on the OEM truck's roof; any length over about 6" cut off.
5). I may have to also hollow out the rear cross bar tubes end cap and cross bar security stuff to do the next step.
6). Now here is where I need some help. The NISSAN OEM Side Bar and the POWERFUL UK side bar are both 55 mm in diameter. I want to taper down the ends of the two POWER UK roof rack side bars so they will slide about the 6" (aforementioned overlap) in to the rear of Truck's roof OEM Bars from the rear (Male/female connection type). For about $25 I can get a tool to Flare out the ends, but I haven't seen tools I can use at home or found any techniques to reduce the size in the opposite direction (aka Swager). Anyone have an idea about how this can be done?
The only one I have is to take a pipe cutter for 2" or greater pipe diameter, remove the cutting wheel, put roof rack tube in a vise to secure it, and using some propane heat and the (wheelless) cutter keep making tighter turns around it to compress it from the outside evenly starting from the end and working my way in (use a caliper measuring tool to check amount compressed as I go along).
7). Then once modified I can just slide the ends of the POWERFULUK tubes into the OEM tubes, maybe drill oneor two hole(s) (seal 'em) to place a flush fitting bolt to secure the NISSAN CAP OEM Rear Cross bar, and the newer POWERFUL UK and the OEM tubes together.
8). Then with the use of the Rear Mounting Plate hole, line up where I have to drill hole sin the CAP roof to secure rearend of the PowerfulUK Roof Rack to the vehicle. I'll probably make hole matching brackets/plates for the inside of the CAP roof attachment points. I can even make them with a tab to the outside that has a hole that can support an after market clothes bar.
So, any ideas how to modify.reduce the end of the side bar tubes would be greatly appreciated, because I will only have one shot at making it work or waste about $500 bucks! Do machine shops have the capabilities/machines to do this? I'd gladly pay a few buck to get it professionally and precisely done right the first time.
When done, I'm hoping to have a nice secured smooth looking OEM style Roof Rack the full lenght of the vehicle's combined roof's without any added coupling, etc showing.
Thanks in advance for any assistance you can offer with this matter.
1 - 20 of 36 Posts
