1 - 1 of 1 Posts
Would like to install LED's in front & rear turn signals. Plan on using vled load resistors. Question is can I use one 3 ohm resistor in each tail light assembly for front & rear lights or do I need to use four 6 ohm? Would like to avoid installing resistors in engine compartment if possible.
Looked at all 3 fuse boxes, can't verify if each side is controlled by a single fuse.
1 - 1 of 1 Posts
