Hi all. I have a 2002 Nissan Frontier, 5-speed manual, sitting in my garage. The engine is blown and I'm in the process of replacing it. I already have the old engine out and looking for a replacement engine. While I have everything down, this would be a good opportunity to replace quite a few parts; clutch, fluids, etc. So hopefully this forum will help me. Prior to the engine blowing, I had a problem with the auto locking hubs making rattling noise when in 4x4 mode after I serviced them. Looking to re-fix that also. As you can see, I'm pretty fidgety with my cars.
_______________
Your Nissan Factory Warranty gives you basic coverage for 3 years or 36,000 miles on your Nissan. Have you explored what Nissan Extended Warranty coverage can do for your Nissan vehicle?
The engine lasted 107K miles. It started by leaking antifreeze into the oil and ended up blowing up completely. No chance of rebuild. My opinion has always been a used engine instead of rebuilding. It is a lot more cost-effective also.
To my fellow Marylander, I'm in the Baltimore area.
welcome abaord! i am over here in western maryland. while the engine is out i would replace everything that needs to be replaced, like timing belt and what ot.
