Hi, just put new Polk's in my front doors.Just wondering if I wired them correctly?Can someone tell me which colors are neg. & which are positive?Thanks,Rod.
IDR.. been a while since I did mine.. You can use a voltage meter to find +/-.
I just installed my front and rear polks and the funny thing is that when I used my circuit tester, both wires came up positive (on all four speakers)! I also tried connecting them both ways and I couldnt tell the difference in the sound, both sounded fine. This happpened on both the front and rear speakers.
^voltage meter even a Batt. tester will do -/+.. if it's reversed it'll show "-X.X volts" or the needle goes backwards.
ok, I called Crutchfield and here is the info they sent me:
10 AMP FUSE
"AUDIO"
PASSENGER SIDE DASH PANEL
20 AMP FUSE
"RADIO"
PASSENGER SIDE UNDER HOOD
The dash tweeters are wired in parallel with the front door woofers.
At the Harness:
Left Front Spkr + BN
Left Front Spkr - BU
Right Front Spkr + L.GN
Right Front Spkr - 9 RD
Left Rear Spkr + GN
Left Rear Spkr - BK
Right Rear Spkr + GY
Right Rear Spkr - OG
At the Speaker:
Left Front At Speaker + BU/WT
Left Front At Speaker - BU/RD
Right Front At Speaker + WT/BK
Right Front At Speaker - BU/BK
Left Rear At Speaker + BU
Left Rear At Speaker - OG
Right Rear At Speaker + BU
Right Rear At Speaker - OG
