When I put the truck in reverse and let go of the brake, my truck squeeks like crazy from the front end. I have no idea what's up, but it's loud. There's a tiny squeek when I'm moving forward, too.
What is going on!?
Is it a constant squeak, or is it one that sounds like it's coming from a rotating part like a squeak, squeak, squeak that gets faster, and kinda louder the faster you drive then sorta goes away when you're going fast enough? if so, check your u-joints, assuming you're 4x4.
I just had a rear one go out a week ago and that's what it sounded like only on mine it was loud as all get out going forward and you could just kinda hear it in reverse.
It's a rotational squeak. I just washed my truck and sprayed the rotars ... no squeak now ... but I'm afraid it will come back.
Dumb question: what are the U joints? Where are they? And can I spray/lube them?
(And worst of all ... how much to replace if it goes that far?)
Cool, hopefully it was just dirt or a rock
As for the u-joint...
It's easiest to see on the rear of your vehicle, look underneath and you'll see where the drive shaft and the differential/transmission, depending on which end you're looking at, come together are u shaped. In between there is a + shaped joint that holds them together, that's the u-joint. On the front there are the factory skid plates in the way so they're a bit harder to see.
If you can get to them, check all the little rubber seals where the joint connects to the drive-line and differential and transmission. Be sure to check all 4 points on all 4 of the joints, I thought my squeak was coming from the front but had someone get out and listen and it turned out to be the rear. When they're going bad you can see the rubber coming apart and chunking/flaking off.
You can't grease them, I ended up replacing mine with an OEM one cause he said it would be a couple days wait to get one with a Zerk fitting so I just had him replace it with what he had. Cost me $50 for the part and $130 for labor, not sure why it took so long, not really a hard fix. You could do it yourself depending on how confident you're feeling :) I'd recommend getting a stronger, beefier, one with a Zerk fitting if you need to replace it...I just wanted/needed my truck back so I figured I'll just replace it again when it goes out.
here's a pic, not our truck, but you'll get the idea
What did you spray the rotors with??? I have the same truck with 62K and also had a bad squeak. Mine was the brake sensors, which also made more noise in reverse than forward, but I changed my brakes a few weeks ago and now its gone. Just a thought, if the noise comes back, try checking your brakes.........safety first!!
Try cleaning your 3 rubber hood mounts, clean them off, where the touch the metal at, then maybe even put a tad of grease on the contacts. Its amazing how much noise those can make....
