1 - 9 of 9 Posts
I am trying to mount a handheld radio mag mount antenna to my 2013 Frontier roof.
Is there a method/way to get the antenna wire inside without using the door or the window? (please keep in mind I am NOT a truck/mechanical person, but I am old and short...)
Or is this way good enough for the camping trip I'm about to embark on? The back seat will not be occupied, so the window will not be opened and closed. However, the door will be opened and closed a lot, which I why I choose the window. I do not know if the window pressure will harm the antenna wire.
Thanks for your reply.
I would find a good NMO mount and drill the hole. NMO is what the vast majority of public service vehicles use. Done properly, it is watertight. The antenna can be unscrewed and stored when not needed (or in a garage)...
Second option would be to bring the existing wire down the back of the cab into the vent behind the back seat and into the cab. Still leaves a lot of wire banging against the truck at road speed.
Another option would be to mount it in the bed or on the back bumper and run the wire underneath the truck, through the firewall, and into the cab.
Running it through the window or door will work on a temporary basis, but will eventually crush or break the cable. It also tends to leak when raining, as the water will run down the wire and end up inside.
What type of radio are you connecting?
Just a small handheld GMRS radio to use for a 2-month camping trip - nothing at all permanent. If worse comes to worst, I can always use the rubber ducks and cut the transmission distance a little bit! ::grin::
Thanks!
I took my satellite radio antenna wire through the cab mounted brake light. Just unscrewed it and slid the wire in. From there I popped off one of the grommets on the back headliner to pull the wire through then popped it back in. I then ran it along the rear window gasket and down behind my rear seats, under the doorsills and to my dash. Hidden and looks good but isn't permanent at all.
Reactions: Kizardling
Great tip, thank you.
From a fellow Mountaineer in WV.
· Super Moderator
If you go through the door seal enter from a side and not at the window level as I ended up with a bit of water on the floor mat once.
1 - 9 of 9 Posts
