Trying to find tech data on the 2nd Gen Frame.
Crude outside channel dimensions are 6.875" height x 2.340" width.
But does anyone know exactly what the specs are?
Specifically Wall Thickness or Gauge?
AMS/Material Spec?
Looking at doing a one-off mod and trying to engineer best fasteners for the project.
If I remember right(.09-.100, truck’s not here).
I just drilled and tapped to hold location and later welded.
Where I just used bolts, I plated. Other areas through bolted.
Whistler,
Who's bump stops are those?? I like the mount. You are Titan swapped in the rear also correct? Could you mount the bump stops on the inside of the frame also??
Bump stop holders are mine. I designed and machined them.
Had them anodized.
The actual bumps are Radflos.
Titan swapped in the rear?
No,Frontier M226. Trutrac limited slip.
Bora 1.25 spacers. Changing to 1.75. Need a little more clearance.
Mounted to the inside?
Not in my case. That is where my shocks are mounted.
