Scott says they won't fit a '93 Pathfinder.Any idea what years this will fit? I need a set for my wifes 03 pathfinder
Yep still have them. PM me and we'll get them sold. Thanks Pete.Do you still have these? I'm assuming these came out of your 09. If so, I'll take them from you for $95 shipped. Let me know. Thanks, Pete
I think they would.Will these work on '05 Frontier LE?
Do you have alloy wheels? Check these pictures out:Hmmm I want to buy them I just need to sure if they will work on my truck.I just checked courtesyparts.com and all the number are not too clear.
I know they will fit in aftermarket alloy wheels, but you'll still have to have them reset for your truck. Did you order your new wheels with tires already mounted on them?I just ordered 20" Boss 330's (Black) minutes ago. I wanted to put the sensors in these new wheels since they should be programmed already and keep my stock sensors in my stock 17"s that came with my truck. What do you think? Will this work? I don't have a clue!
If you want the sensors installed in the new wheels and tires, then they won't be ready to go. You'll have to take them somewhere and have each tire removed from the rim, have the sensor installed and then have them rebalanced. The shop that does that for you can probably turn off the TPMS warning light.Yes I did. Discount tire took tooooo long and didn't know when they would get a certain set of wheels in. So I changed my mind and got a different set with tires mounted on and are being shipped to my door ready to go. But, I want to put the sensors on the new ones when they get here.
